No skills
Greetings all, might get a couple of cabinet scrapers (and a burnisher :wink: ). Are there any brands to avoid or any that are recomended? or are they all much the same?
adidat":2nha11uc said:cabinet scrapers are just a bit of flat metal, cut up an old saw, that will do the trick.
jimi43":f7as2d56 said:That being said...you could use a screwdriver shaft for a burnisher as well but the Clifton one is a lovely thing...kind of makes you at least think you can do a better burr with it! :wink:
The Carbide sharpener for scrapers (not the one on the website at the moment) that Matt used to sell at WH was better than any steel burnisher. Unfortunately, they're not sold there any more...but I have one :mrgreen: - RobPaul Chapman":3799vcz4 said:jimi43":3799vcz4 said:That being said...you could use a screwdriver shaft for a burnisher as well but the Clifton one is a lovely thing...kind of makes you at least think you can do a better burr with it! :wink:
+1 for the Clifton burnisher - a lovely tool.
Cheers :wink:
Paul
Unless I'm missing somat Matt (which wouldn't be the first time :roll: ) the one on the site at present is the sharpener (with the hexagonal grinding thingie on the cylindrical bit)...one of which I also have as opposed to the cabinet scraper sharpener which has a smooth cylinder :? Confusion here Matt, so some clarification needed. I had a look on the site this morning and could only see one of the carbide tools, whereas at one time there used to be two side by side - Robmatthewwh":2utxptni said:
With you now Matt. At one time, if memory serves, both the sharpener and burnisher were listed side by side...a duplicate listing as you suggest might make it clearer - Robmatthewwh":3lv3oau9 said:Ahaa!
The sharpener is in woodworking / tools / sharpening / carbide sharpening along with the pocket sized carbee sharp.
The burnisher is here in woodworking / tools / planes / cabinet scrapers with all the other scraping goodies
Maybe if we duplicate the listing for the burnisher in the sharpening section too it would be clearer?
Register today and take advantage of membership benefits.
