Box joints in plywood
Grahamshed
14 Apr 2012
Oxfordish
I have been trying to make box joints ( finger / comb joints ) in plywood for a drawer but the ply is just 'shattering' all the time.
I have tried half inch baltic birch and 3/4 inch far eastern ply, both look to be good quality. I have also tried a backing piece and front piece which help but not that much.
I have tried the router at high, medium and slow speeds but no real difference.
Joints in solid wood seem quite good.
Equipment is a shop made table, Steve's jig, wealdom 8mm straight two flute cutter.
Any ideas anyone ?
Well I was thinking it, Phil posted it... :oops: Still nevermind, must box joints be used for what your doing? could you use a sliding dovetail instead??
Wonder if a spiral cutter would be any better, haven't used them myself.
I dont HAVE to use box joints but I would like to. I have a small cupboard in the house made from 1/4 inch ply with box joints and that looks good.
I was also thinking upcut spiral and it says it is for ply etc so maybe I will have to try that.....
I've done finger joints in baltic ply for drawer boxes and they've been okay, little bit fuzzy without a backing board but easily cleans up during sanding. I use a spiral bit and the best quality ply I can find (currently Chudova birch ply from SL Hardwoods), it pays to use the best because any small voids or tiny patches of delamination and ply will spelch for England!
Wrong tool for the material and joint? TS a lot better. Or a different joint.
I agree with Jacob, although not impossible to get the fit and finish you want from the router table I'd definitely plump for the TS solution.
I've not used ply for this so I can't help, but if you go the TS route be aware of the added dangers. Apart from the general guarding issue, you have to lean a long way over the saw to operate an equivalent jig on a TS. One of the most common accidents on a TS is people falling onto the blade at the end of the cut. Not as common as lost fingers, perhaps, but quite common nonetheless.
Steve
Thanks all. I do not have a table saw ( and with my eyesight the way it is I have no intension of getting one :) ) so I will have to try the upcut spiral. They do seem expensive and hard to find though. The size I want is out of stock at Wealdons and Axi.
