So, I'm routing out some hinges on a kitchen I am building and I'm struggling to get my Festool 1010 into a couple of the gaps I've left myself - still learning, and probably should have routed the face frames before putting them on. Hindsight.
I've got the UJK Metric guide bush set I use frequently in all my routers, but I'm trying to find out if there is an adaptor for the little GKF600, whose smaller footprint might be just what I need.
Bosch seem to give conflicting info on that, but one of the kits you can get the Bosch in appears (from the picture at least) to supply a base that may or may not accept the standard Bosch SDS. In which case, the overpriced SDS Leigh adaptor will fit and work, albeit a rip off at £27.
Anyone used one? Anyone have any buying tips on this? Cheapest kit appears to be from Powertool World, especially as I have loyalty points to use up.
Thanks in advance.
Thanks in advance.
