jorgoz
I'm in the progress of working on a book-shelf/display stand and have run into a problem. There's too much room between the shelves making it look too tall. Frames are 1200mm high and 400mm wide, shelves are 1200 x 352.
How to solve this ? Add another shelf or lower the frames.
Adding a shelf, but how to make i look good, frames are glued ?
Lowering the frames, would be a last resort. I've bookmatched the legs and used blind dovetails, would hate to start over with a half assembled/glued frame.
The bottom shelf will be attached with 3 mm thick brass stretcher plates. The shelves will be tapered along their height to where they meet the frame
