Speaking from my own experience with the bandsaw, probably not.
Its a machine that you will use a lot but mostly for pretty standard workhorse sort of stuff.
You may be tempted to make a circle cutting jig or a high fence for ripping and you will occasionally adjust the table angle, none of which really require a book for inspiration or instruction.
You should pay attention to the type of blades to use, basic maintenanace and make sure the fence supplied is true .
Also, I would recommend that you learn how to cut straight, freehand, as knowing what blade drift your machine has will help you true up the fence if required. This technique/excercise can be found on line.
There are many web sites that will offer lots of good information and instruction including this forum and its members.
beejay
