Quantcast
blum movento one side not closing fully
Helvetica
4 Apr 2011
Ireland
As per title. Left side holding open by a few mills. If I push it closed it pops back open. Two other drawers are perfect. I don’t have depth adjustment with blumotion. I tried moving the whole left mechanism back but it stil stops short. Any ideas?
AJB Temple
Finely figured
13 Oct 2015
Tunbridge Wells
There are numerous different iterations of Movento. Some have soft close, some have tip-on push to open and some have both. Depending on the width of the drawer and the type of mechanism, the two sides may need to be synchronised with a sync rod fitting.
Alternatively your drawer or cabinet may be slightly out of square or one of the runner mountings slightly out of level. I presume you have drilled the hole in the correct place in the back of the box? If the pin is not going in, then the drawer will not close. The current Movento units have lateral, fore and back and up and down adjustment of a few mm.
doctor Bob
22 Jun 2011
Matching Green
This can happen if the unit is not square, or the drawer is not square, or if the drawer is a wobbler.
Sometime the solution is to pack the front or back of the runner out to re-square.
Helvetica
4 Apr 2011
Ireland
I checked the drawer dimensions and it is square to within half a mil. The cabinet is good too.
The front to back adjustment seems to be an add-on, would this sort it? Cannot for the life of me see the issue.
For what it’s worth they are - Blum Movento 760H4200B Full-Extension Drawer Guides with Blumotion Nom. Length 420 mm 40 kg
softtop
14 Jan 2010
South Lincolnshire
I've had a few dodgy blum drawer slides in the past - try swapping it out for another one and if it works it's a dud.
Helvetica
4 Apr 2011
Ireland
Sorted - the depth of the runners was slightly off, user error! I’ll know for next tine. Cheers lads
