The Weegie
Hi guys,
Got a problem with the screw that inserts into the top clamp. The saw I am using is the SIP 16"
TIghtened the screw and noticed that the key slipped in the screw. Took the key out and tried a second brand new key. Still Slipped.
I am unable to get the screw to come out. It will not budge. I have tried a small bit of oil. Tapping it with a hammer, and using pliers to try and turn all without success.
Any ideas. I was thinking of drilling through the screw to see if this will enable the screw to fall out. What do you think.
Could get replacement from SIP, but think that the blade clamps are overpriced.
