black and white?
sunnybob
wysiwyg
11 Oct 2014
cyprus
I have been asked to make something that really needs the blackest and the whitest woods I can get.
BUT.... not talking ebony or ivory costs.
Also dont want to just paint the wood.
Is it possible to stain walnut for example to get it very dark?
At the moment, I have no supply of maple, is there any way of making beech much whiter?
How white is white oak? I can get that but have never used it.
I can also get poplar, but am told that does not finish nicely, true or false?
I dont want huge quantities of either wood, just something around 2 ft square outer surfaces
Bob, you can stain or otherwise colour wood to make it black but have you thought about the difficulties of sanding here? There are a few challenges, including the possibility of sanding through the black skin to paler wood beneath but perhaps the main one is whatever the white material ends up being any black dust in its surface could make it look very dingy indeed. And conversely pale dust will be very noticeable in the grain of the black wood. So you'd need a reliable way to clean the surface afterwards if you sand.
Scraping is a better option often when there are strongly contrasting woods present, but I understand manual work like that might not be feasible for you.
...not talking ebony or ivory costs.
How about faux ivory?
What about white plastic? (Don't baulk too quickly, faux ivories are basically off-white/cream plastic!)
Bone? It's been a standard stand-in for ivory since ancient times.
Yes, jet black is easily possible. But you can make nearly any wood very dark or thoroughly black a few simple ways (although a few are tantamount to painting the wood black).
All common methods are surface treatments though, the wood is not coloured through-and-through, so any post-build sanding then becomes a potential issue.
You can make any wood very pale, nearly white in some cases, using two-part wood bleach.
But can you get that there? And anyway, do you want to mess with strong caustics and concentrated peroxide solutions?
White oak is, er, the colour of oak :) It can look very similar to European oak.
Poplar finishes fine, or at least it can. But it's quite variable in colour and you may have difficulty finding a piece that's uniformly pale.
That statement "wood X doesn't finish well" is usually a bit vague and sometimes (more often than not?) it's more about how much work it takes rather than meaning exactly what the words say. Poplar for example can be made to look a convincing stand-in for cherry, and then finished just the same.
I really dont want to get into chemicals and paint for a quite small one off item so
I've spent the morning scouring every woodyard in 40 miles from me, and managed to get some maple. Its very rough sawn though and looks almost orange so i am hoping that after going through the thicknesser it will lighten up.
Bought some more walnut too. That is now getting scarce here, one woodyard I used to buy from said they wont stock it anymore as its too expensive and no one will buy it.
Definitely higher prices to last year.
I only bought 1 plank of each but the cubic metre price was;
for the maple was 2720 euro (£2347)
and the walnut was 3300 euro (£2848)
I spoke to one of the men about poplar, he said it finished well and showed me some poplar ply. I was amazed both because I thought all ply was birch, and how white and smooth the poplar was. But he said it marked very easily, even a finger ring pressed against it gently would mark it, so thats out for that reason alone.
If you were in the UK I'd solve your problem for you. I've got some black wood. I'm afraid I'm not up for sending it by courier to Cypress, though. If you can think of another way, drop me a PM.
