I'm going to be making timber sub-frames to fit windows into heavy section oak main/outer frames. The windows are to be fitted from outside, sealing against the sub-frames.
The sub-frames are 17mm thick oak, rebated 5mm deep and 35mm wide; I can choose the overall width of the sub-frames, depending on how much I want to be seen on the inside of the window, but they're likely to be between 60mm and 70mm. The longest piece of sub-frame is 1.5m.
I have a router table which I haven't used yet and am wondering whether these rebates are best cut with a long straight mortise bit, holding the width of the sub-frame sections vertically against the fence, or with a smaller straight cut bit in two or three passes, with the width of the sub-frame flat against the table?
Many thanks,
Ian
Many thanks,
Ian
