Hello Elaine,
If you need any further help or advice on the choice of tools for piercing I would be happy to send as much information as you might need to take an informed decision. I have an NSK unit plus a micro motor and other units. There are benefits and drawbacks to all of them.
The NSK is very expensive (£400+) and easy to damage if the air pressure and flow is inconsistent. Only friction fit dental burrs can be used. Speed is only accurate if the required air flow at 35psi can be delivered. The psi and air flow will be true with other air tools. Most small compressors can work at 35psi but it is the size of the reservoir tank that determines working air flow and the time it is available.
There are alternative air tools but most require oil lubrication with the possibility of oil spattering on the workpeice.
Compressors are designed to work intermittently to replenish the reservoir tank. With a small compressor you will find the NSK and other air tools will empty the reservoir within a couple of minutes. A small, low cost, compressor may not be able to replenish the tank to drive the tool. It will then be working constantly providing air direct to the tool and there is a danger then the compressor will overheat. An appropriate compressor will, probably, be expensive. I made the mistake of buying a small compressor and would also need to take advice if I choose to correct my error.
If you are only piercing occasionally a micro motor might be a better choice, many different types of burrs will fit the unit and are readily available. It is possible then to sand, cut and shape as well as pierce.
Success with piercing is enhanced if the correct burrs/cutters are being used and a clockwise cutting action is observed.
Philip
