Bench Grinder problem
Chisteve
18 Feb 2020
Chichester West Sussex
I have a Sealey 8 inch bench grinder, when using it today together with dust extraction etc it tripped electrics in my workshop
I reset the trip and tried it tripped again so confirming it’s the grinder that’s gone puff, I’ve not had a chance to look at it yet but thinking it’s going to be unrepairable
Just wondering if anyone has any knowledge on these things on what to check with a volt meter ? as it’s been good till today, although I’ve worked it hard - I’m no electrician - but any pointers would be appreciated
It must be electrical as did not suddenly stop just tripped the electrics
A couple if simple checks.
Plug the grinder into a different socket see if it still trips
Plug something else into the socket to check thats ok also see if the wires in the plug are tight as if one is loose/intermittent that could cause a trip
how old is it? it could be the capacitor needs replacing inside, I replaced one in mine after about 4-5 years, it's also worth checking the fuse in the plug.
Thanks for the reply’s it’s not the socket will hopefully have a closer look at it shortly hopefully it might be the bushes as didn’t smell burnt out, it came to me second hand and as noted I’ve worked hard for the last couple of years will keep you updated
Try carefully spinning up the wheels by hand, then turn it on. If it does so without tripping breakers then the capacitor need replacing. If it trips the breaker then something else electrical is happening.
Yes I’m aware of this as it went pop when using suggesting it was not the capacitor - planning to have a look at it today
I would have thought the cost of rewinding would be greater than the cost of replacement.
Going back to that capacitor, it's likely to have gone short circuit, hence tripping the c/b.. Try starting the motor with it disconnected. Should run in either direction if you give it a spin. Caps very rarely fail open (almost never).
Of course you may have a shorted winding in which case as you say, terminal.
You could always do what I did, make you own out of a hair dryer! (Bit underpowered though)
Depending on what you grind, if its general rough grinding any of the cheapo will do, I had screwfix one for years.
But since wood turning I opted for the Axminster 8" wide wheel, AW200ASG. Excellent for sharpening my gouges and fine tools, so much quieter and virtually vibration free.
Kept the screwfix for everything else, like cold chisels, metal shaping etc ie rough work only.
https://www.axminstertools.com/axminster-workshop-aw200wsg-wide-stone-grinder-230v-107685
