Belt & Disc Sander
Mikegtr
UKW Supporter
18 Jun 2020
Morpeth
The disc sander is 6" diameter--not hook & loop--I am about to convert the metal disc to hook & loop. I have a number of 5" hook & loop sanding sheets--no 6" hook & loop sanding sheets. Do you see any problem using the 5" sanding sheets on the 6" disc when converted to hook & loop? (The only problem I can see probably would be: 'Don't try sanding on the 1" part'!)--any other issues you can foresee ?
Many thanks.
