transatlantic
Boom!
I need to replace a bearing on my wheelchair. The bearing is located in a piece of round tubing (about 5mm thick) that isn't much bigger than the bearing itself. I've had a look around and there seems to be quite a few different types of pullers. Which one would be best suited to this job, seeing as I don't have much area for the puller to work with?
The first image shows the two bearings I need to change, and the second image shows the part of my wheelchair in question.
