Hi all, just registered - hope to ask some questions about my plans and also then keep this going as a build thread hopefully.
We are hoping to complete on a property near Witney, in Oxford at the end of this month.
There is a barn which has been there for 20-30 years (or more) that I'd like to convert into a workshop. I have spoken to a few architects about planning and it seems unclear as to what I can and cannot do.
The overall property sits on about 1/2 an acre. The property was build for the local farm's labourer and I believe the Barn / Shed has evolved over time and currently is about 75m^2 big, right adjacent to the property border and around 2900mm at peak height.
There is some concrete poured under the roof but its poor and needs to be removed.
It is difficult to tell from the pictures but the main structure is steel, some corrosion, with a mix of steel and wood bracing going over the top. It certainly doesnt look sturdy and whilst the centre columns look to be sunk into the ground, the outside ones look to be sitting on some form of a block. How this has remained standing for so long is beyond me.
So options, 'fix it', completely remove and rebuild (planning might be an issue) or something else?
I'd like to end up with around 100m^2 of workshop space. I have a few CNC machines and often retrofit / fix them, so space with roof height is key for me. Then the usual messing with cars / bikes etc.
Thank you.
Thank you.
