Barley Twist
Lonsdale73
21 Feb 2015
County Durham
Saw this and was wondering if it could be achieved with a spindle or bowl gouge or would it need a specific carving gouge?
Dalboy
18 Sep 2008
Canterbury United Kingdom
Barley twists can be made with some careful marking out and either a carving chisel or even a round file/rasp.
Not sure if you wanted to put a picture up as there was nothing there
Lazurus
22 Sep 2017
Norfolk Broads
I used to make them on a trend router lathe, wish i had kept it now as it was a unique tool that produced excellent results.
Robbo3
28 Jan 2012
Oxfordshire
Stuart Mortimer is the man for barley twists, not just for candle sticks & finials but for eggs & complete hollow forms.
- http://stuartmortimer.s411.sureserver.com/
IIRC he marks out the twist, cuts down the centre of the twist (or twists) with a tenon saw & widens the cut with a flat chisel (may be a gouge - can't remember) before resorting to rasps or files & finally long strips of abrasive pulled backwards & forwards over each twist.
Edit: Later posts indicate a small plane rather than a chisel ... which rings a faint bell.
Edit 2: Ignore earlier edit. Having found the Youtube videos, he uses a gouge kept specifically for the job but states that a bowl gouge with a suitable grind would be acceptable.
Links in later post.
Jonathan S
15 Mar 2019
Monda,Malaga,Spain
We made them at school.....used a saw, plane, chisels, round file and sandpaper.
Sent from my SM-J530F using Tapatalk
timber
1 Sep 2014
near Bedford
I have a couple of Legacy Ornamental wood turning lathes and can do a lot more than just barley twists.
I started with a Trend router lathe and I got well and truly hooked !!!??
If interested let me know. I am 85 so soon be selling up.
Lonsdale73
21 Feb 2015
County Durham
Take it you didn't have any joy selling the Trend?
timber
1 Sep 2014
near Bedford
The Trend went a long while ago. The Legacy Lathes can do so much more.Such as fluting planing and quite a lot more. The Trend could do a spiral but was very limited .
Yojevol
Clocking on
29 Jan 2017
Cheltenham
I have a Trend which I could be persuaded to part with.
Brian
Lonsdale73
21 Feb 2015
County Durham
So, getting back to the original question, can a spindle or bowl gouge be used akin to what is seen in the video or is that tool a specifically for carving gouge?
Inspector
Nyuck, Nyuck, Nyuck!
18 Jun 2006
Saskatoon, SK., Canada
I think the carving gouge is the way to go but why not try your spindle gouge. If it doesn't work to your satisfaction you can get the carving gouge. If you want to play with surface texturing you'll be able to get more use from the gouge.
Dalboy
18 Sep 2008
The problem with turning tools even though they are sharp they are nowhere near as sharp as carving chisels so it would make harder work of it unless you want to spend ages getting them razor-sharp.
Better off getting the microplane as Doug suggested
Lonsdale73
21 Feb 2015
County Durham
Just found one of his videos on yt. Got as far as the marking out bit and found myself wondering "HTF does he do that?" Replayed it several times and still marvelling at it. Likely to do so for several more times afore moving on to part 2!
TFrench
6 Jul 2015
Leics
Beat me to it Andy, I was just about to post a link to that!
Robbo3
28 Jan 2012
Oxfordshire
Andy, could you kindly post links to the other 2 Richard Findley videos for those of us that aren't on Instagram.
Stuart Mortimer - https://www.youtube.com/watch?v=V5kKJpR9xSI
1 - https://www.youtube.com/watch?v=Wm-wWjlAtTw
2 - https://www.youtube.com/watch?v=4GSvMlaj4J8
3 - https://www.youtube.com/watch?v=elwKX6ySJTI
4 - https://www.youtube.com/watch?v=vrdv7O91L7k
5 - https://www.youtube.com/watch?v=3PjLJFYekos
Lonsdale73
21 Feb 2015
County Durham
Is it just me or are parts 4 and 5 identical?
