slemishwoodcrafts
I am planning to resew some smaller ash logs into planks and liked the idea of building a sled for my bandsaw to run the logs through. Just wondered if anyone has any experience or tips they could share?
heronviewer":16ux3b89 said:I built one using Kevin Bradys design which has a sliding back rest and the log is held by three screws at each end. It works very well. I had to adapt the design for my bandsaw (a Kity 612). Unfortunately I can't find my working sketches, nor can I find the design on the internet. Maybe someone could help with these ? I could post a photograph of it if that would be of any use.
heronviewer":31xiydcv said:... nor can I find the design on the internet. Maybe someone could help with these ?
In the second pick you can see there are extra threaded inserts in the base, allowing the two knobs to be inserted at different positions along the length of the base, as well as allowing some movement due to the slots in the back plate.memzey":12fn7adj said:You may be right, although if that were the case you would be rather limited in the length of the log you could plank up, unless I have missed something?
