Hi I'm a newbie who foolishly bought a cheap sander from Aldi. It's a Challenge 710/4789D. It melted its drive belt! True, it melted it. When I stripped the machine down I could see the reason for this. The axis of the shaft that the driven pulley runs on was skewed relative to the one for the drive pulley. Also as the belt came off the driven pulley at an angle it rubbed against the baseplate and got very hot. The cause of the leaning shaft is twofold. First there is a hole in the casing under its lower bearing which had protrusions out of its side and second that the holes in the top and bottom (plastic) bearing housings are not truly circular. These two factors allow the bearings to get out of alignment. It looks as if the manufacturer made a mistake with the drilling of these holes. I say this because for some reason they have inserted a (brass) cap under the lower bearing. This rests on what small part of the edge protrusions in the hole it can find and this is supposed to hold the bearing straight and hence shaft upright. But it doesn't work properly of course. I know I can fix it but it's the last cheap power tool I ever want to buy from Aldi. I admit that Challenge isn't Aldi's tool name. Maybe their tools have improved? Do they supply instructions for dismantling and repairing their tools? Can we buy spare parts for them? The only spare I could get for this Challenge was a drive belt. I got it from Solent Tools. They were very helpful. But the belt cost £9 which seems expensive. My question is - should I apply grease to the driving and driven (metal) helical gear wheels that turn the driven roller and pull the grinding belt? I ask because wood dust sticks to grease very well and the machine was full of grease. What does wood dust do to gear wheels?
