http://www.axminster.co.uk/tenon-plate- ... 0ta-950506
Axminster say," This accessory is a simple alloy plate that lifts the workpiece above the table. This means that you can machine the top and bottom surface of the work, such as when creating a tenon. It can be mounted next to the mitre fence and clamp so as to make the machining of end grain material as safe as possible.
" This means that you can machine the top and bottom surface of the work, such as when creating a tenon "
" such as when " Can this tenon plate then be used for other things?
