Axminster rip fence upgrade
Duddybugs
New member
9 May 2014
Suffolk
Hi,
Just wondering if anybody had any experience of the Axminster rip fence upgrade -
three w's axminster.dot-co-dot-uk/axminster-rip-fence-upgrade – sorry, not enough posts yet to embed the link properly :(
I think it would fit well on my Kity Bestcombi 2000, which has dreadful fences. Also wondering if the tilting planer fence upgrade is worth doing, as the planer fence on mine is as good as useless. The fences are spoiling an otherwise excellent and accurate little machine.
Simon
I've got Axi's £14 fence upgrade for my small bandsaw. It's better than the one that came with the machine (Record Power 250) but still not great.
Thanks for that, but it's the £75 one I'm looking at. Seems to get good reviews on the website.
Simon
This one I have on my TS 200, it is great but for the table saw I would ideally have liked a longer mounting bar. It is plenty big enough for a band saw!
It is ridiculously easy to fit and adjust.
I have never regretted buying it.
I hope that helps.
    15.8 KB
    14.2 KB
I had one for years and it is and has been fine.
You really need to fit to it a supplementary short fence that stops at the blade cutting edge otherwise you will get jamming/kickback problems.
Roger is ,right if you are using ghe fence on a tablesaw. I have one that fits over the fence and can be clamped down with bolts which fit into the slots on the extruded aluminium fence. Not shown on the pictures above.
It is the same principal as my thrown together tenon jig.
I have used my magswitch jig to guard the blade area.
    110.3 KB
Thanks for the replies...
All sounds positive, think I'll go ahead and order one. The mounting bar is actually slightly longer than the Bestcombi one so not an issue..
I always use a short supplementary fence when ripping natural timber, nice to know there's an easy means of mounting one.
If I buy the planer fence upgrade as well, I'll be able to loose the rear fence mounting bar, which will make some sort of out feed table easier to realise.
Thanks for the pictures, very informative.
Simon
Tim - did I miss a step somewhere? There seems to be an aluminium extrusion across the front of both the saw table and the R/H extension, behind the new fence mounting brackets...
David
