mudman
- Joined
- 11 Feb 2004
- Messages
- 993
- Reaction score
- 98
Hi all,
First time back here for a while and now I pop up again with a problem. :roll:
Haven't been doing a lot of turning lately but recently I've been looking at the lathe and realising that I need to get back on it.
Anyway, I was always a bit dubious about the accuracy of my Axminster M950 lathe but recently using the scroll chuck and pin jaws, it was obvious when I mounted the workpiece that there was a considerable amount of runout. I've always known it was there but for what I wanted to turn, it made things very awkward.
So, I've had the chuck apart, re-mounted the jaws, cleaned everything up and still no different.
I then had a look at the junction between the chuck and spindle shoulder and noticed a gap. This I thought would be the reason and so made a rough washer out of mdf and tried again. Even worse this time with the runout plainly visible when rotating.
So, I've had a good look at things and this is what I've come up with.
Has anyone got any advice on this?
My prime suspect in this is the insert being a different thread to the spindle although I am a bit unsure whether there should be that much play in the jaw slides. Can anyone confirm if this is usual?
Thanks in advance.
- 1. The jaw slides seem a little loose on the chuck and can be moved back and fore by a small amount. (less than half a mm I guess).
2. There is a small amount of damage to the chuck insert's external thread that screws into the chuck body.
3. The internal thread of the insert seems to be different to the spindle thread. When you put it on partway, there is a considerable amount of 'play'. The manual says the insert thread (Type D) is a 1"x8tpi UNC thread. However, checking with a whitworth thread guage I have, it gives a perfect match to the 1x8 whitworth.
Thanks in advance.
