Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
Axminster have their hobby morticer on offer at the moment.
<www.axminster.co.uk/axminster-hobby-series-aw16bmst2-bench-morticer>
I have the older version of this, and really like it.
Some things of note:
1. Mine came with a reducing collar so that it takes two sizes of chisel shank. I'm not sure if this is still the case, but I've had no problem finding chisels for it, despite the comments on the Axminster page.
2. The work clamp is vastly improved if you stick sandpaper to it with D-S tape. At that point it's brilliant.
3. Using good extraction right next to the chisel slot really helps in softwood. It is a low power motor - good enough for the job but there's not much spare. I've had it stall in damp softwood (don't ask - it wasn't fine cabinetry!), but helping the chips clear easily is a good idea.
4. The raiser block and drill chuck adaptor are both handy, and, given you get free postage on the main unit, it might be worth getting them at the same time. There's only a sleeve bearing for the drill chuck shaft, so it does need oil fairly often.
Just sayin'...
E.
(other morticers are out there, but I really like mine!)
Just sayin'...
E.
