Seeing how useful the handwheel is on the Jet 1642 at our club and not having one on my Axminster AWVSWL1200 I thought I would use some of the bits in my metal bin to make one.
The side panel removed from the left hand side of the headstock.
Threaded bar with a chamfered nut to centralise the bar inside the headstock.
Steel discs threaded through to make up the handwheel.
Discs being screwed onto the threaded bar.
Cover plate back in place.
All pieces screwed on.
The finished item, finished and polished.
This now makes it much easier to screw chucks/faceplates on and off without using the screw in spindle lock, I will use a thread protector to pop the drive centre off as the knock out bar can't be used, but as my faceplace type work out weighs the spindle work this isn't an issue, hope this helps.
Regards Chris.
Regards Chris.
