Hi and nice to meet you.
I want start making tobacco pipes and I can afford only this small lathe (AWSL). The problem is that this work needs to catch wood pieces inside of the chuck and they usually have 50-60mm width.
A friend of mine suggested me to buy the Axminster 80mm O'Donnell Jaws and the K10 chuck, but I am not sure if the maximum distance between these jaws at the K10 chuck will be enough to hold the wood. However a Goliath 125mm chuck would seems to be a better choice about its size for this work (in combination with these jaws), but I wonder about the weight of this, as I don't know if it is too heavy for this lathe. The other problem is that the K10 is temporarily out of stock now.. :|
As I see, Goliath is 3 kilos and K10 is 2 kilos.
Do you think that I will have any problem if I order Goliath, because of its 1 more kilo? Has anyone try it?
Has anyone these jaws installed at any of the above chucks, to measure and tell me what is the maximum internal distance of the 80mm O'Donnell jaws?
