Well after being on the phone at around 4.00 pm to axminster,the replacement part arrived at 9.00am today.Cant fault that for service!!!
I looked at the new part and some dimensons were slightly different,the new part had a 10mmx 1.5 metric thread on it ,the old one has M8.The three cross head screws that hold the cog to the large wheel have been replaced with better hex head screws.
Heres 2 pics of the new part compared to the old.Nice bearings with no play . I can use the old spacer as the dimensions are the same.
First thing i had to do was drill out the thread in the arm where the cog fixes to.I used a 8.5mm drill and tapped the hole with a M10x1.5 thread.
I fixed the cog into the hole with the chain attached and hand spun the drive.The chain was catching on the weld where the powerfeed handle attaches. So i removed the cog and ground some of the weld back.
I fitted the cog and chain again and spun it,noticed that the new cog was sitting further out from the face of the machine than the old one.It was out of plane with the other larger cog that the chain meets with.So i removed everything again and drilled a slight 12.5mm recess a couple of mm deep in the outer face of the threaded hole id just tapped.The cog sat much better and was almost perfectly in plane with the other cog.Heres it all fixed back on.I bolted on the large wheel with the two rubber tyres.
Finally after all this its still not feeding properly,it must be the rollers that are out.Ive cleaned the serrated feed roller.Ive noticed the outfeed roller seems way too low.So its back to adjusting these.Do any one know how to adjust them accurately without some sort of height gauge???I only have s disl gauge on a magnetic base.
