Architrave help please
Skeety
4 Feb 2014
Berkshire
Hi All,
Just finishing off a couple of door frames and have hit a slight problem with the fitting of the architrave.
The new architrave is wider than the original plain one and is profiled.
The problem I have is at the top of the doorframes the new architrave is overhanging the glazed section at the top by about 5mm and 10mm on the other frame. I have already fitted and primed the frames and replaced the glass. Ideally I don't want to remove the trim and glass then pack the apertures out as my other half would be less than happy.
Any suggested workarounds from you all would be appreciated!!
Cheers,
Jon.
