Approx cost of beech for a bench top?
morrisminordriver
17 Dec 2002
Seaton, Torpoint, Cornwall
Hi all,
can anyone tell me (very roughly) how much I'd need to spend to buy some beech for a work bench top approx 2" thick, 30" wide and 72" long.
I'd prefer it already planed and thicknessed.
Ta
Mike
I believe prices up here range between £18-25 / board foot, but that's roughcut.
ummmmm....make that a cubic foot...
<prone to the odd blonde moment......
you could do what I did, and buy some maple or beech kitchen workshop - its aready nice and flat, glued up etc..
not sure if it would work out cheaper
Hi Mike
My solution was even cheaper and much more stable - a sheet of OSB faced with hardboard screwed onto the surface. But that wasn't the question you asked :wink: .
Yours
Gill
Unless you are dead set on a beech top, a pretty good alternative is to buy a solid core fire door from one of the places like Travis Perkins. They come in two types, a very dense chipboard variety and a block laminated wood variety, the latter being just like what you might make up yourself, except it is skinned with plywood.
I used one of these which I faced with decamil for a platten for vacuum veneering and found it very flat and stable so when a friend wanted to build a bench, he was persuaded to use a similar door as a top. I helped him build the bench and it worked very well. He used another thin sheet of ply as a sacrificial top, secured with few countersunk screws.
I recall I paid something like £70 for the door and at that price it beats making a heavy top up myself.
Chris
