One part to be made and another to be bored/reamed.
It's the bolt and bracket that holds the non trunnion end of the Shopsmiths main table. There is slop between the bolt and the bracket which makes the table move under not much pressure. Until it's secured I dare not use it as a table saw, let alone with a dado blade or a molder head.
As you can see, the bracket is threaded which seems wrong to me, much less metal to hold the bolt and it has worn.
What I'd like is for the bracket to be bored/reamed just enough to get rid of the threads, then a new bolt made to give zero slop. The threaded end of the bolt needs to be the original size so as to screw into the main tables stanchion.
The 2nd pic shows the bolt partially unscrewed.
Being an American made machine it will require a non metric thread. (Are American threads the same as Imperial?)
Much gratitude and beer tokens if you can help me.
