Exactly! Go watch someone ripping on a HolzHer or the like and that's what you'll see - there is no mechanism for holding the cut open. I've use on of these saws in anger only two or three times but it isn't a problem. The biggest problem is remembering to take care setting up cuts so that your rip cuts and crosscuts are done where the horizontal/vertical gaps in the bed are (so you don't saw your bed strips to pieces)mrbingley":3igng8jk said:I wouldn't have thought it needed to have anything to keep the cut open.
Once the sheet touches together at the end, it's self supporting and the riving knife keeps it open before and after it touches together.
I've seen wall saws used in kitchen carcass shops and working to tolerances of 1mm or less, although, yes, the trades do tend to use them as a quick and dirty sheet stock breakdown mechanism used before applying materials to the spindle, router, etcengineer one":2lkvkfaa said:.....just that i think holzer users tend to work
somewhat more quickly, and probably with slightly less care
than many working at home might, also I think the saw will
be used more slowly because of the power differential.![]()
do you push the material past the saw for doing rips along the 8'
