cerbie
Having read Tony's review of his new saw (and yes I AM jealous), I have been prompted into this.
Let me say from the outset - I'm new to this dark art of the wood, relatively, so ..........
My only previous experience with a table saw was a SIP 315mm contractors saw, and I burnt the motor out on that !! Soooo, I have now picked up a FOX F36-527 T/S at cost of 220 euros, about 152 sterling.
I bought this in preference to the Ryobi 1525 s/c, a look alike, as I had seen/felt a Ryobi 1526 in a store here and did not like it at all.
I actually wanted, and would have bought (I think) the SIP 254mm t/s, if I could have found one here at UK price, but as I said, I'm new to this, so perhaps a cheap piece of kit in the first instance is the way to go - practice an' all that.
First problem occurred as I put the tin foil legs together, 4 of the 32 bolts had knackered threads, not too serious, but this was the first part to be touched !! I detected a subtle dark cloud of impending doom wisping through my workshop. However, the rest of the assembly was OK.
Having put all together, plug it in and fire it up.
I pressed the button and saw the blade leap up, seemed like a foot or more, but that may be an exaggeration, frightened the daylights out of me.
No soft start then.
Oh, and a bit on the noisey side.
Having put a piece of scrap oak through, I found the guide appears to be parallel but after a little repetition the clamp let go letting the guide wander off. Hmmmm, maybe it was me, perhaps.
The magnifier on the guide doesn't, but it does obscure the scale and I find I am having to bob and weave all over the place to see it.
The throat is not wide enough for me to pass a hand into without difficulty, but I do have big mitts, apparently, so the blade/rive knife assembly is not a comfortable thing to play with. The throat plate, plastic, is insufficient, which allows the end of a (narrow) work piece to dip in the void. Not nice.
This t/s has a laser on top of the rive knife assembly, why?!! What is the point of that?
It also has a mounting point for a router so it can double up as a router table. But the top is ribbed ally, a router is rather heavy and as a result I foresee a deflection issue if it was to be used as such.
In summary, a big disappointment, but I suppose I was expecting a little too much for my money?
If YOU are thinking about a similar purchase - don't.
No soft start then.
