Reggie
Following on from my hijacking of another thread on benches here: post785723.html#p785723 I've started this thread up.
On further inspection, the plans I based mine on are from here:
http://www.plansnow.com/weekworexvie.html
I've attached a jpg of my bench from sketchup so you can get an idea of what I'm doing or attempting, I basically ditched the drawers but that's essentially the frame I was looking at, but swapped out laminating? the sections together and going for solid wood, 70mm x 70mm legs, everything else 45mm x 70mm except the top which is 45mmx200mm sections. I haven't added the bolt holes into the sketchup image yet for the front rails, just in case you're wondering how they're attached, it's only my 2nd attempt at anything in sketchup so if anything looks wrong, let me know.
