I am currently doing up my shed. I have suspended all interesting work while I try to sort out practicalities like, universal extraction, electric points and storage. I made an mdf box for example that sits by the door and has three shelves. Goggles ears and mask. Idea being a place for everything and everyt..... anyway You get the drift. :roll:
Only reason I post this one is it worked out well. Lot of clamps stored Vs. Space used. And the designs do ok and its all really offcuts. Hope someone can benefit. Each size clamp benefits from a different designed shelf. The Middle size g clamp holes I cut with forstner bit and a chisel then rubbed load of glue in there to settle the mdf. The rest is obvious.
Only post because it seems to be an cheap efficient method of clamp storage in a corner. 20 in a foot square of dead space.
That and my Space rocket plans were rejected by NASA. Bit of a blow.
Bottom shelf. Dowels.
Middleshelf. Holes. The design means the clamps just sit steady. You dont have to alter the threads. The larger clamps in the photo above need the dowel.
Topshelf.Nowt!
Overall:
Anyway.
Cheers.
Chris
Topshelf.Nowt!
Overall:
Anyway.
Cheers.
Chris
