Has anybody got first hand experience of one of these, or seen one in the flesh? I first saw an ad in the back of one of the comics, I made an email enquiry to the company to see what they had to say about it, and was obviously so taken with the response that I forgot all about it for 6 months. Over £80 to solve a problem that I haven't noticed seems a bit steep to me. I was wondering if anybody had used one and experienced a moment of rapture?
I'll agree the blade guides on the Record 350S are a fiddle to set because of the way they're hidden behind the blade guard and the silly variety of hex bolt sizes used, but losing 50mm of cut (even if I'm never likely to use the full depth) seems like a lot to pay to solve a niggle. I also seem to remember a school of thought that suggests this type of bearing guide exerts greater point loading on the blade than the disc type used by Record?
http://www.yandles.co.uk/precision-roll ... 350/p14583
I'm sure I've seen something similar from Axminster, and various outfits in the US, but with a lack of clarity about which machines it might suit, whereas this one is aimed squarely at Record machines (by an ex-Record employee if memory serves) which seems like a smart move for the UK market.
These precision roller guides are manufactured in the UK specifically for the Record Power models BS300E - BS350S - BS400, refer to the chart below for models and recommended blade widths.
There is NO drilling, filing or any modification required unlike many cheap after market guides currently on the market.
Manufactured in steel and aluminium, these guides will make a very good saw even better, they give superb blade control have low heat generation to the blade and produce no sparks.
Both side support rollers and thrust roller are adjusted by a cam system giving precision setting longer, and allows full contact to the blade, this eliminates any blade twist, cutting contours will particularly appreciate the blade control.
Available in the upper guide assembly as this takes on 80% of the work.
*Please note fitting these guides will result in a loss of 50mm in depth of cut.
