Buying a first bandsaw
AJBaker
8 Jan 2025
Switzerland
I'm still a fairly new woodworker, but I've got reasonably proficient at making things with hand tools. I have a nice bench with decent planes, and so far I've made do with hand saws, even for long rip cuts. I can follow a line, and then plane it straight and square.
That being said, I think it's time I added at least one power tool beyond my electric drill. For Christmas my wife bought me a small 100£ bandsaw, but it was hopeless, I couldn't get the blade to stay on the wheel and there was rubbing inside the top that didn't seem right. I returned it, I could tell it would be more hassle than it was worth. I now want to replace it with something halfway decent in the budget price range.
I have very little space, so I reckon it'll need to be a 10" (or max 12") model.
It'll mostly be for rips in 20-50mm wood, plus some scroll work. If I could resaw boards for bookmatched panels that would also be great, but that might be asking for too much.
Looking around on forums, it seems that Record Power is the consensus for a reliable cheap bandsaw. If I go for their 250 model, will that be a smart choice? Or splurge on the Sabre version? Or am I on the wrong track and I should be looking at something completely different?
I'm not worried if it isn't the very best, but I do want something that'll work for years and won't cost me more time fixing it than it saves in sawing.
Thanks!
I upgraded from the small Axminster bandsaw to the Record BS250 in May last year (I couldn't see any advantages with the Sabre version at more money for my needs, which seem similar to yours) - very pleased with it. I bought mine from Yandles, next day delivery on a pallet - tail-lift wagon, pallet truck and delivered into my workshop.
I have a Sheppach Basa 1.0 which has been good. It's only a small machine and light enough to move by picking up. It's only a small machine though so don't expect to be ripping huge bits of wood. It's great for small jobs though
I have recently upgraded to a recordpower rpbs12 but that is a much larger machine and is super heavy. I'm not going to get rid of the basa though as I think the small machine will still be great for finer work.
I would see the record 12'' as a starting point if you want to resaw boards over a couple of inches wide. Horsepower is required and the more the better. I nursed along an underpowered saw for a few years and that was a lesson in frustration. One of the good points about bandsaws is the bigger saws do not take up a lot more floor space. A 14'' will not need much more room than a 12''. Just remember wharever the saw you do need room to push the bit of wood through. My bandsaw is near the garage door so long bits of wood feed out the door.
Regards
Regards
True! The bigger bandsaws are a lot heavier though. I'm not sure I have the space for a stationary bandsaw, I might like the convenience of a portable one...
Thanks!
If you are only going to make straight cuts in wood 20 - 50mm thick, I would go for a table saw rather than a bandsaw. Table saws make much straighter cuts and with a good blade the result can be as good as a planed edge. I have a good sized shop with both a table saw and a 14" record band saw. The table saw gets 10x of the use as the bandsaw.
Thanks, but there's no way a table saw will fit, there's nowhere near enough space in my workplace. I reckon that the only realistic alternative for rips for me could be a handheld circular saw.
You can easily go round in circles for ages weighing up which bandsaw to buy. It comes up as a topic regularly on here and the Record 250 seems to get good feedback.
I started with the equivalent Scheppach machine and it didn’t struggle to rip 50mm hardwood stock with a good clean cut. Using a decent blade with the right tooth configuration makes a big difference. Tuffsaw blades have a good reputation but they don’t do overseas sales. I don’t use them but Axminster anldo have a good reputation for their blades.
Having looked after my Scheppach machine it sold easily for a decent price when I upgraded. I’d expect the same with a Record machine.
I have the Sabre 250, upgraded from a cheap £100 scrapper like you. Can cut up to 90mm (I think). Brilliant bit of kit with a good blade in it.
I've made furniture with it, and a regularly re-saw 50-60mm thick plank of oak, maple and walnut.
One thing everyone always says - think how big the maximum you'd like it to cut, then buy a bigger one :)
I bought a Record BS500 about 20 years ago. As I recall it was the biggest machine they made at the time. It does what I need it to do but I've never been that impressed with it. The guides are finicky to adjust and the top guide has never been exactly parallel to the blade in both the vertical and the horizontal plane. The blade tension indicator is completely worthless. As mentioned earlier, Record supplied my first set of blades and they were terrible. I was ready to junk this thing until I bought some good Axminster blades. The motor doesn't seem to be that powerful although it is rated for 2.2kw. In fairness, I have hauled this machine to a few different countries and back to the UK. It could be some of the windings have been damaged but Record doesn't offer any help in finding a new motor. I wouldn't buy another one from them.
One up for the Sabre 250 here too. Better quality than the standard 250 and more features. Very happy with it and yes 60mm hardwood is no problem.
Hmm... Cash is a bit tight, so I was leaning towards the 250, as a saw costing 400CHF is still bound to be better than the cheap 130CHF saw I had. But now I'm wondering if I shouldn't cough up the extra 110CHF for the sabre...
Just comparing the blade guides would make my choice for me, Sabre use's proper bearings orientated in the direction of the blade anything else is bad design or just built down to a price.
I have the Axminster equivalent of the Record 250 - light hobby use for 12 years with no problems bar replacement of the blade guide bearings (simple).
Comfortably cuts through 50mm of hardwood and will do 100mm if the stock is fed slowly. The main thing to get right is blade selection - sharp, right TPI and correct set on the teeth.
The bearings were the one issue I had with my Sabre250 - 4 of them seized solid over one winter, but they were very easy to replace, they're a common size and they didn't cost very much.
I grabed the sabre 250 today. It was 490CHF, 110CHF more than the normal one. Hourly I made the right decision, I'll try it out soon!
