Hi, I need some advice please.
I have been laying oak floorboards onto Envoy adhesive underlay. Horror of horrors I've discovered that some of the backing cellophane has not come off cleanly and is trapped between underlay and the boards above it. It makes a 'crinkling' sound when you step on the boards. Luckily I've only done 3/5 of the room and the trapped cellophane is somewhere under the last 4 rows I've laid.
Question is how can I lift these 4 rows to effectively re-lay them? They will have partially adhered to the exposed underlay just to make things more of a challenge. They'll just be tongued into each other though, no skirting board is pinning them down yet - they are genuinely 'floating'. I really don't want to scrap the whole job and start again due to the complicated laying (under door trims and through the doorway continuing onto the landing) I've already sweated over.
Appreciate I'll need to discard the underlay, clean up the boards I lift and use fresh underlay. Any help would be gratefully received. If I can fix this now before going on I'll take that hit, I'm gutted I didn't spot this sooner. Hope you can help.
Many thanks
Mark
Many thanks
Mark
