Advice on using my Random Orbital Sander
UTMonkey
6 Jun 2012
Chesterfield
Hi all,
First of all I think it is a great piece of kit, but my first project using it has identified some issues.
I will be gluing layers of hardwoods together, to do so I want to make sure they are flat (and smooth?).
Anyway, the pieces in question are roughsawn, 4x4x1 (inches) in size.
On goes the 60 grit, and within a minute or two I have a nice clean surface. All is well, apart from the fact that there is a very obvious curve to the face, higher in the middle, lower on the edges.
It seems to me that whilst I am not applying pressure (which I understand you shouldn't), I am letting it overshoot the piece too much, which may be contributing to the undesired effect.
Thinking about this, given the size of the pieces should I enclose the piece with some "sacrificial" wood to pass on the curve problem off the piece?
What would you do?
Thanks in advance
Mark
Thanks for the advice, I suppose your right, will sanding an already flat piece assist the bonding process?
Any standing after planning could curve/dent the piece and cause less glue surface so a weaker joint. Plane only. Glue depending but to smooth of wood your joining could also weaken the joint.
If you are rounding over by running the ROS over the edge - stop running it over the edge. Just take it up to the edge (plus a bit to make sure you have got there).
