Hi,
Looking for some advice on preparing my windows for repainting please.
I started looking a one window to see how much work is going to be involved (this is not quite the worst example of 19 windows!)
Where the paintwork deteriorated over the years there's wet rot at various stages:
Problem 1 (wood wet, bit soft but good enough?):
Either the ends of beading or the cill itself.
I hope I can get away with a preservative then primer/undercoat/gloss. Once I've scraped back to the wood, how long will it take to dry out (assuming it doesn't rain)? Are all preservatives the same or is there one you would recommend please?
Problem 2 (rotted away)
Preservative to stop the rot then filler? Is there a recommendation for a particular filler please - it would be very thick in places!
Problem 3 (rotten window beads)
In the second picture the beads are so far gone that they should be replaced, but would you replace or preservative/fill where it is less than 1cm at the end (first picture)?
This is my major job for the summer and I want to get it right so that I can get away with just sanding/painting for the next few years. Thanks for any advice.
Colin
Colin
