Digizz
I'm having a fairly major loft conversion done (lots of technology in there) and am designing and building a sink plinth or countertop. I'm planning on using solid Walnut (American Black Select Grade) to match the timber floor in the main part of the loft.
If you're interested, this is my gallery with pics:
http://www.siliconpixel.com/gallery/main.php/loft/
This is what I've come up with so far:
Thing I need advice on are:
1) what kind of joints would you use in the top surface timber (I guess it'll be 2 or 3 planks joined together for a top)
2) What kind of joints would you use in the side and front skirt (biscuit etc)
3) Any special precautions to take given there will be some water around the area
4) I'd initially thought of 3 thickish timber parts butt joined to form a simple apron and top arrangement. What would you do to achieve a similar (but maybe better) result?
5) What thickness timber would you use - 1"??
6) Any other advice or hint's/tips?
Many thanks,
Paul.
Many thanks,
Paul.
