Mykee
How accurate is accurate. I'm having a great deal of frustration getting rid of those tenths. I come from an engineering background where the tolerance was one or two tenths. Aaaaaaggghh.
Mike O.
Mike O.
When two mating components fit together, without undue clearance and are fit for purpose.Mykee":35ih8k20 said:How accurate is accurate. ....
Yep, that's pretty much it. I make a working drawing(s) (usually 1:1 or 1:5 with a cutting list) but they're only a guide and more often to see what the proportions of the piece actually look like. Components are cut to size but thereafter as Chas says, actual dimensions are irrelevant - RobCHJ":37kbjuot said:When two mating components fit together, without undue clearance and are fit for purpose.Mykee":37kbjuot said:How accurate is accurate. ....
I find in working in wood the actual dimensions are in the main irrelevant, a storyboard, even if this is only the major component is far more conducive to getting an accurate fit than a rule.
AndyT":1j7ruo14 said:I agree with Chas and Rob.
But to offer a simple example of how accurate "making to fit" can be: if you measure the difference between a tenon that fits properly into a mortise (hand pressure only, but won't fall out) and one that is too loose, it can be as little as a thousandth of an inch - a single, translucent shaving.
You're absolutely right, but did you know that the domed end of a Japanese geno hammer is specifically designed to squish a tight joint to fit? The theory is that it's made a shade tight, then tapped both sides with the hammer to ease the fit. When it's glued the wood then swells and you've got a righty-tighty fit. I didn't realise until a few days ago when I saw a clip on UToob of a Japanese chippie doing exactly this process - RobAndyT":1rwgme4p said:I agree with Chas and Rob.
I first saw the technique used by this guy at the European Woodworking show a couple of years ago https://m.youtube.com/watch?v=bT5qLzbidRs Sadatsugu Watanabewoodbloke66":22uovg4v said:You're absolutely right, but did you know that the domed end of a Japanese geno hammer is specifically designed to squish a tight joint to fit? The theory is that it's made a shade tight, then tapped both sides with the hammer to ease the fit. When it's glued the wood then swells and you've got a righty-tighty fit. I didn't realise until a few days ago when I saw a clip on UToob of a Japanese chippie doing exactly this process - RobAndyT":22uovg4v said:I agree with Chas and Rob.
transatlantic":2wh3t5qk said:Fortunately we can re-create those shavings![]()
phil.p":g86u1nmv said:transatlantic":g86u1nmv said:Fortunately we can re-create those shavings![]()
Oh excrement ...... here we go ...![]()
Trevanion":2eeyrhub said:.....When I was in college the tolerance for a pass grade was at most a 3mm gap on a joint.......
MikeG.":1dvg2u1e said:Trevanion":1dvg2u1e said:.....When I was in college the tolerance for a pass grade was at most a 3mm gap on a joint.......
Blimey! A well motivated beaver could manage that.
I also have an engineering background and have difficulty accepting that timber is not steel (or brass, alum etc) but I still aim for accuracy to 0.01mm. I get around most of the issues by using metalworking machinery (Mill and Lathe) helped by the fact that I tend to make 'small' items from well seasoned exotic hardwoods - I'm currently working on a presentation box for a set of pens - 180mm x 108mm x 38mm - some of the joints are 1.5mm wide and I have a 7mm hole in an 8mm thick side. The top is 4mm thick with 2mm square rebates so you can appreciate that working to ½mm is no good.Mykee":22pbe46t said:How accurate is accurate. I'm having a great deal of frustration getting rid of those tenths. I come from an engineering background where the tolerance was one or two tenths. Aaaaaaggghh.
Mike O.
Register today and take advantage of membership benefits.
