Accuracy of bearing guided router cutters for template use
Knaus
31 Aug 2016
Pennine Dark Peak
Hello,
New user here :)
Seeking advive from those more experienced, on buying bearing guided router cutters
I am speciafically trying to find out which brands are acknowledged to have a high accuracy between the diameter of the bearing and the diameter of the cutter
The reason for my equiry is that I will be routing puzzle joints, from template, in plywood up to 3/4" (19mm) thickness
Any recommendations gratefully received - thank you in advance
Great minds...
When I saw you post I thought of this.
http://www.wealdentool.com/acatalog/Onl ... m_269.html
Very useful cutter. This is made in 19mm birch ply and laminate, made a template and used the above cutter to make doors.
    35 KB
