Got any pics? Might give people inspiration.
I buy epoxy resin by the bucket load for about £55, how thick does it need to be as it's normally pretty runny?
Claymore":30sf6k24 said:
aye I have used epoxy (araldite type) in the past which was fine but I need LOADS for a 4ft Corian Intarsia project
Without knowing the project perhaps a better job would be the correct colour coriander adhesive. Will be expensive though!
Hot glue, is it on a backer??
Whatever you do, don't get that ''non-sniffable'' epoxy from China, it's like snorting napalm (I would imagine).
There is an invisible Nomorenails .If you don't want flexing then an Epoxy or structural CA type glue might be better
Matt
STIXCLEAR made by everbuild. Crystal clear grab adhesive.
CLEARFIX3 also made by everbuild is listed as clear, 88438 code at toolstation.
Sumogrip and similar adhesives don't stick anywhere near as good to solid surfaces as araldite or dedicated solid surface adhesive for some reason?
