Great idea, would it be okay to do this on my 1 and only saw, is it likely to cause any damage?
Brian.
Great idea, I use a similar method, fixing a lollypop stick with sandpaper applied to an old blade with glue, which of course is just flat. Your idea is better in that you can sand curves. :wink:
Like the box, looks good, never tried this on the scroll saw.
Take care.
Chris R.
Brian,
High-jacking the thread, if I may.
Nice box. A couple of howdoyoudothat questions.
1. What is the depth of the box (ie back to front) scaling by eye it looks close to or above the 65mm max depth for the saw.
2. How did you get the drawer fronts to contrast? ( I'm assuming you used one block of glued wood ) Not had coffee yet so I may be missing a simple trick.
Brian
