AJB Temple
Finely figured
I need to send the blade in my Bosch GCM 12 GDL gliding arm compound mitre saw off for sharpening. This is a 72 tooth Bosch blade tct 305 x 30 x 2.4mm.
I would like to stick a finer tooth blade in (for wood only) for a good finish and minimal break out and am looking for recommendations. On my radar are
Swedex which is 96 teeth, 3.2mm kerf. Slight negative rake. £117.
Bosch Z96 which is about £80 and will also cut aluminium- not sure who makes blades for Bosch.
Freud LP60M, 96 tooth. About £82.
Trend also do a pretty cheap 96 tooth blade for under £30 but I want lasting quality so wonder of this is false economy?
I will also be getting a blade with far fewer teeth for quick cuts.
Also any recommendations for blade sharpeners? I am in Kent near Tunbridge Wells.
Thanks, Adrian
Thanks, Adrian
