• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Sold Bosch GCM 12 GDL
Big Trev
14 Dec 2020
Marden, Kent
Again hardly used.
Price £495 ONO.
Product Highlights​
With the most accurate cutting results in the Bosch range, the GCM 12 GDL Professional is the top choice for jobs that demand highest precision. The mitre saw´s innovative, maintenance-free glide arm is extremely robust and offers high endurance. Thanks to the glide arm´s hinge design, the GCM 12 GDL Professional is compact from front to back. Equipped with a double line laser and top-quality saw blade, this mitre saw ensures highly accurate cuts.
Equipment & Application​
The GCM 12 GDL Professional is intended for cross, mitre bevel and groove cuts in wood, timber beams, and wood composites as well as in board materials and floor panels. It is compatible with the Bosch Click & Clean dust extraction system as well as various stands.
Additional Information​
The GCM 12 GDL Professional also includes features such as intelligent brake system, precision double line laser, and soft start.
TECHNICAL DATA​
The most important data​
Cutting capacity, 0°104 x 341 mm
Cutting capacity, 45° mitre104 x 240 mm
Cutting capacity, 45° bevel51 x 341 mm
Mitre setting52 ° L / 60 ° R
Bevel setting47 ° L / 47 ° R
Tool dimensions (width x length x height)1100 x670 x740 mm
No-load speed*4,000 rpm
Saw blade diameter305 mm
Saw blade bore diameter30 mm
Weight*32.1 kg
Rated input power1,500 W
Total vibration values (Sawing wood)​
Vibration emission value ah1.5 m/s²
Uncertainty K2.5 m/s²
Noise/vibration information​
Sound pressure level93 dB(A)
Sound power level106 dB(A)
Uncertainty K3 dB
The A-rated noise level of the power tool is typically as follows: Sound pressure level 93 dB(A); Sound power level 106 dB(A). Uncertainty K= 3 dB.
