The Lidl plunge saw
flh801978
21 Dec 2008
Sheffield uk
I was at my local branch of Lidl this morning for the plunge saw at 8 am the doors opened and a scrum of workmen rushed in to get the bargains
There was only 2 plunge saws luckily I got one but in 10 mins all the 18v drills had gone much to the disgust of many more chaps coming to the store at just past opening time
So here it is
It looks good everything seems to work well all thumbscrews are easy to use scales look good the tracks are of a heavy profile and the joiner is sturdy
Maybe someone who has a festool track could comment if their track would work ( If one wanted a longer length !!)
Ian
I am also just back from one of the three local Lidls. Arrived at about 8.20am, and was the only person looking at tools. They had two plunge saws (maybe the standard allocation by store?) about eight drills, five each of nailers and each type of sander. I picked up a ROS, nailer, two packs of nails / staples and two packs of sanding disks. Still in boxes by front door, but at £45 the lot with a 3 year guarantee don't think I can go far wrong.
Terry.
There were at least 4 in the Reading South store this morning -1 now - its in the boot of the car.
Also got the a pair of removal type trolleys look very sturdy.
phil.p":5g0eapg6 said:
Afaik, all their electrical stuff has a three year warranty.
the reason I asked was the website doesn't indicate that the nailer has three year warrenty, wondered if the box said different. I hope to visit my local store at lunchtime
Box says three year warranty.
Terry.
Mate got the track saw this morning. The track is nice and thick so quite rigid, especially as it is only 70cm. Smooth running along the track.
The only comment I would have is the chip breaking strip is the same as I had on my Woodstar track which was pretty in effective. I replaced with festool strip and it works great.
Hoping to get an 18v impact driver at lunchtime if there are any left.
Got myself the nailer, nails, trolley dolly and some multitool accessories today. Lots left at Sowerby Bridge, one plungsaw
no track saws or impact drivers left in high wycombe store. Got a multi tool bathroom set for £6 though. Will be very handy.
Dumfries store had 8 saws and countless impact drivers got some sanding discs and nails and staples and set of multi blades .
Jim
Am I going to regret not getting this? I've been after a reasonably priced circular saw for a while, mainly for cutting PAR boards down to size.
What's the difference between a plunge saw and a circular saw on a guide rail?
Quicker and easier setup mainly.
With the anti splinter strip fitted a much better cut can be achieved as well.
Due to the design of them you can in some cases cut doors down without having to remove them from the frame etc. etc.
HTH
Roger
Does anyone know if this will run a Scheppach saw track? They look similar but would be good to know for sure.
Sent from my HTC One_M8 using Tapatalk
It's easier to "plunge" it through a piece of wood, if you don't want to start at an end or cut out a section.
I don't know about the Scheppach track, but I've tried mine on a festool track and it runs fine on that. just needed a tweek of the adjusters.
