Kalimna
- Joined
- 18 Nov 2009
- Messages
- 1,275
- Reaction score
- 1
Greetings folks,
To elaborate on the thread title, I have a 7-8 year old Aximinster radial pillar drill (back when they had a Perform range) which has been fine until recently. Initially I thought it was just blunt cutters (Record forstner bits), but even with a hardly used twist drill bit, the bit gets stuck drilling anything greater than 3/4" thick. Even repeatedly clearing the waste doesn't really help matters much. I can still hear the motor turning, so I suspect the belt is slipping on the pulleys.
So, does this sound likely? And if so, how might I remedy this? I had a look inside the drive head (?name?) and didn't see any obvious way of tightening the belt, but then I'm not especially mechanically minded!
Cheers for any help,
Adam
Adam
