Charlie Woody
I am building a large bookcase - very basic design, see Sketchup below - that has to go up a long flight of stairs.
My idea is to biscuit joint the upright supports to the underside of the shelves and glue these in place, but, dry fit the biscuit joints into the top of the shelves. Apply finish. Dismantle the dry joints to take upstairs and then dry fit them again, so that if required at a future date the unit could be dismantled.
I am thinking of routing a shallow groove in the wall side of the uprights to screw some of http://www.screwfix.com/p/mending-plate ... f-10/16050 to the upright and the wall. These would go along the uprights just under the top and in the middle shelf. As I will be using oak, might need to use brass ones (if available).
I have three questions please:
1. Will leaving the dry biscuit joint be secure enough given the height of the unit > 2m?
2. Will the mending plates be enough to stop the unit toppling, given the dry biscuit joints, height and the fact it it to sit on existing carpet so levelling could be thrown out once loaded with books?
3. If the answer to 2 is yes, if I cannot find brass mending plates, if I apply finish to the grooves will this stop the plates staining the oak?
