Doug71
I'm on with fitting worktops to the kitchen I've fitted and could do with more advice from people who know what they are doing!
Because of bent walls and keeping things in line etc the carcasses are about 10mm off the wall where the hob will go. When the worktops turned up today they are only 600 mm deep which is only going to give about 5mm overhang in front of the doors. I was thinking I could pull the worktops off the wall 10mm as there is a 20mm thick upstand but realised there is a glass splashback behind the hob which sits on the worktop so really the worktop needs to go back to the wall.
Solutions I have thought of
The splashback is solid colour so I could pack it off the wall on a backing board to cover the gap?
I can maybe pull the worktop say 5mm off the wall and just caulk behind it?
I can't see that sticking a slither of worktop on the back will work very well?
Any other ideas?
I wish I did these things more often then I would see these problems before they happen
If the worktops were 615mm there wouldn't be a problem
Edit to add they are laminate worktops.
Any other ideas?
