I agree with the above, it's best not to use flexi if you can avoid it. I would suggest you look at proper steel tubing probably spiral wound which is the cheapest. When setting up my dust extraction I thought that soil pipe would be the best and cheapest option.....it wasn't, spiral steel pipe was by far the cheapest when buying new.
When extending the system again and keeping an eye open for companies that may be disposing of ducting I have found that I can get all the ducting and fixings I want for free by simply asking around. The Big caution is to check what they were using the ducting for. Sometimes it had real horrors in it...! I usual look for wood working stuff or metal working places. If it's metal working the tubing is considered 'contaminated' and the companies need to pay for it to be taken away. I did some research into this and it appears that as long as it's either iron or steel and you don't consume large quantities, rub it into open wounds etc there is evidently no cause for concern (but check it out yourself). Wood dust will scour the inside of any tube clean, and the contamination is diluted by the saw dust and not considered a hazard. I was amazed to find that the 'slag' from metal working is simply mixed with other stuff to make it none toxic...evidently it's about concentration levels!
