This topic is kind of linked to the 3 phase topic i started about my bandsaw.
Im upgrading the elctrics to my workshop ,i bought this wylex 5 way consumer unit and i need a 32 amp ring off this,a 6 amp light ring and a 16 amp supply which im using just for the bandsaw.
The consumer unit has a 63 amp switch but ive bought seperately a 63 A RCD.(should i just change the switch for the RCD?)
This supply for the workshop consumer unit will be fed from a spare mcb on the house consumer unit(an unused cooker circuit which ive upgraded to 40 amp).
Questions are ,will this be enough to supply the workshop consumer unit?
There wont be much load on it all the workshop machines apart from the bandsaw just plug into the 13 amp sockets.
Also how do i arrange the mcb,rcd,in the workshop unit.Id prefer the light circuit to NOT be fed via the RCD.
One other question i bought by mistake two core swa 6mm cable to feed from the house instead of 3 core.Can i use the armour as the earth or do i need to put a seperate 6 mm earth cable through with the swa .Its going through conduit as well for added protection.
A pic of the consumer unit for the workshop.(maybe i should have bought a split unit?)
