Honest John
I generally buy my timber dry and reasonably stable. I also occasionally come across logs harvested from trees that have come down and it’s a buz to create something from a lump of tree rather than a dry and prepared blank. However, I have rather mixed results with regard to part turning and drying. I have just lost one bowl before I could even take it off the lathe. I reduced the wall thickness to about 10% of the diameter and then watched in horror as a crack opened from the rim and proceeded halfway down the side to about 2.5mm wide. My intention was to rough turn to 10% soak it with lemon oil! Rap bag and leave for a while and monitor. I never got that far. I have had success with this method but not as consistently as I would like. Yesterday evening I was browsing YouTube and found a post from a Turner whom was building a “drying cabinet”. This was fashioned from a cardboard box, a small computer fan and a light bulb. His intention was to rough turn to 10% then pack in this box for several days before completing the turning! This kind of goes against what I have always understood to be best practice, that is dry slowly in a draft free place, and here is this guy creating heat and draft to dry it quickly ? I’ve had better success with thin walled tuned to completion items, but this is not always what is wanted.
My bowl with the big crack in it did not contain the pith, but did have some very uneven grain patterns due to other limbs in the near vicinity. Perhaps it was doomed to failure because of this? How do you guys work your wet wood?
